snewojsnewo
- Joined
- Mar 27, 2024
- Posts
- 1
Hey there - I'm hoping to get some input and advice from this group! I'm planning out my 40ft skoolie with my family of 6 (wife, me, 2 kids, and 2 dogs). Here's what I think I know/think will work so far:
Daily Expected Skoolie Usage: 10-12kWH
Daily Expected Vehicle Usage: 5-10kWH
System Voltage: 48v
Battery Setup:
* 10kWH OR 20kWH Ruixu Batteries - https://www.ruixubattery.com/product-page/ruixu-lithium-batteries-kits-15kwh-20kwh-25kwh-30kwh
* 77 kWH EV6 Battery with V2L capability (this is our daily driver) - this is our “last 20%” when considering Solar coverage. Takes very little time to drive it to a high capacity charger and come back with 80%-90% if solar is not providing enough.
Ideally we’d like to be able to charge our car off our solar setup, but acknowledge we might need other options.
Solar Setup:
* Just under 7kWH of Rated Power
* 16 x SunPower 435W Solar Panel - we’re planning a slide out approach for when we’re parked
* Planning this to be 2S8P based on Victron’s calculator
“Guts” Setup:
* Victron EasySolar-II 48/5000/70-50 MPPT 250/100 GX
* Victron Cerbo GX System Controller
Main questions I have off of that are:
1. Does this system seem robust enough the handle what we’re aiming for?
2. I want to use my car as optional shore power. It can put out 120v @ 16 amps ~ 1.9kWH. Any major concerns or others using this approach that have advice?
3. I had a couple other items in my original plan when using the MultiPlus, but not sure I need them now. Do I?
* Victron Lynx Shunt VE.Can – Power Distribution System (M
* Victron Lynx Distributor – Power Distribution System (M
4. Do I need a combiner box for my solar panels? If so is there one you recommend and why?
I’m planning on doing all this work myself. I’m not an electrician, but I’m trying to learn what I need to make this happen.
P.S. Don’t hold back
System Voltage: 48v
Battery Setup:
Solar Setup:
“Guts” Setup:
