You are not going to back up a 4 down towed more than a few inches. The front tire camber will not allow you to do more than that.bansil said:... So unless you jack knife backing up ...
lornaschinske said:David says that in most states, it's a law that your ball isn't more than 15" from the ground. He said he doesn't think it's an enforced law because he has seen pickups with balls set higher. The main thing is the tow bar is level between the towed and the ball or receiver if you are going "ball-less". If you are ball-less, then there's just not much I can say... in public that is.![]()
You sound like you speak from lots of experience.gbstewart said:as long as it hits you right in the knee cap when walking by it , you should be ok.
I'd hate to be that guy. That would really hurt!
--- David
bansil said:OMG...how to respond!!!!!..
Brass balls on bus.....just don't put a huge bell to lure cows....that may turn the 16 yr girlies on.....but damn what a pain in the arse to listen too...........![]()
:shock: ....so wrong.....just so wrong......if you "lose" ur nuts in the driveway?keith said:also beware in the state of FLA u can not hang your ball at all.they will fine u,and take your nuts. :shock: ......so u have been warn![]()
Those are uptight New York yankees. They moved to FL, said how wonderful it was thst there wasn't all the rules and restrictions like they left up North. Then the idiots started making all kinds od rules and restrictions until most of the native Florida Crackers ( I can use that term... you can't) moved to other places.keith said:bansil ,,u see them flat landers down there don;t have a sence of humur,like us mtn boy's do ,so it a no ball state..lol ..we like our corn liquoir and mtn oyster and women.......
