tinyhousetruck7
- Joined
- Jul 16, 2023
- Posts
- 5
Hi all,
I am converting a box truck into a shepherds hut style home; I realize this is not a skoolie but it is in a similar vein, especially when it comes to the body of the box that I am using (steel construction, see photos). I have some questions I thought skoolie builders might have good answers to. To give you a quick run-down of the project, I am keeping the 20' box on my truck but removing the roof and welding on arched rafters, so it will have a nice and cozy shepherds hut appearance. After that, the interior conversion will resemble a skoolie with a roof raise; framing windows, insulating, etc.
The question I'm stuck on right now is this: subfloor. I know that skoolies have a metal pan floor that they build their subfloor atop. I, however, have 1" tongue and groove planks of wood that sit on top of the crossmembers of the steel bed that is the foundation of the box (see photos). This has served as the only floor of the truck throughout it's life moving furniture and the wood is in good condition. However, I am worried about building my subfloor atop this for the foundation of my home for several reasons: it is unprotected on the bottom side, so I worry that over the years (especially through snowy winters) the wood could rot... compromising my home foundation. I also worry about its ability to keep out insects and rodents as there are some gaps in the corners. Here are options I've thought of to solve this problem:
A) Cheapest/easiest: Leave wood, go on the underside of the truck and coat the bottom of my steel frame and all visible wood with some kind of water resistant paint... not sure what so any recommendations would help. Fill gaps where critters could get in (recommendations??)
Unscrew and pull up all the wood, give it a few coats of a heavy duty primer, then screw it all back in. This would use the wood that's already there but would be tedious (probably 70 screws into steel). Fill any gaps in corners where critters could get up with spray foam or something else?
C) Take out all the wood (could use it for something else) and lay down sheets of 3/4" painted ply. Recommendations on what to use to prime this to protect it welcome.
D) Most expensive/most difficult: And lastly, remove all the existing wood and lay down metal sheeting on top of the steel bed crossmembers, I could wrap up the walls just a couple inches so I would have a true pan--like a skoolie.
Let me know what you think I should do. Of course, would love to use the wood that is already there because like I said, it's already there. But, willing to spend money to fix this if it could be a long term issue. Taking all advice!!!
