Id love to see that setup. As Ive said we are in a desert and our water sources are drying up but it is probably over complicated for our needs yet.
Guessing you mean the reclamation set up. It's planned out and simple. Not sure how well it will work but we will at least be able to reduce some water usage be reclaiming. Basically, everything goes to the black tank except the Shower and Washing machine. So toilet, bathroom sink, and kitchen sink. This keeps out food particles, tooth paste, etc.
Washing machine and shower go into the gray tank from which a pump pulls water through a screen to remove hair, lint, etc. (washer will have lint screens to minimize lint in the tank). Then it will go through two or three filter elements to remove smaller particles, and then through an RO system.
RO systems typically send 19 parts of water down the drain for every part processed through the membrane so the RO "waste" will be fed back to the gray tank.
After RO processing, the flow goes through a UV sterilizer and into the reclaimed water tank to be drawn upon for toilet flushing, showers, and washing machine.
Because there is then a reclaimed and a potable system, we will need three water pumps (fresh, potable, and the reclamation filtering system), and two on demand water heaters (potable and reclaimed systems).
A bit of extra expense but we would like to take nice, long, HOT showers rather than the typical wet, lather, rinse deal.
