jjhomeonewheels
- Joined
- Jul 21, 2011
- Posts
- 12
Hi, thank you all for the advice so far, and on my other post about flooring. Unfortunately, I jumped the gun a little, as my ceiling has multiple leaks. So what I have done, is taken apart the fire escape hatch and the ceiling surrounding the fire escape hatch, (which is where the biggest leaks were originating from. I calcked the **** out of everything, leaving no crack unfilled, so that should fix that problem, but the part of the ceiling that I took down,(which has insulation attatched to it), had rust everywhere. So I chizzled it off and repainted over it with "Rust-o-leum" primer. the next day I check on its status and I noticed a considerable amount of condensation accruing on the ceiling, (the part of the ceiling that I removed, so now the part exposed is the sheet metal seperating the inside from the outside. So, my question for this post is, How do I go about preventing or minimizing condensation? My guess is that because of the metal, that its going to do it reguardless. I've thought of using a spray adhesive sealent. I've also thought of purchasing some new insulation, even though this doesn't look that bad, maybe some higher grade for that area, or just having newer insulation will soak up any water without causing mold or mildew. As always, any advice would be much appreciated. thank you
