Drew Bru
Just had the water pump replaced after a catastrophic bearing failure. Now, while idling, I see some drops of coolant scattered beneath the bus. This could be residual leftover slop from the water pump failure but I'm wondering if there's a pinhole leak somewhere or a leaking hose or something. With the fan running it can be hard to track it down though.
I've washed the engine bay pretty good and tomorrow I'm planning on putting a big sheet of cardboard under the engine and idling it for an hour or so. I figured the system should be pressurized when I shut off the engine (and the fan stops) and any pinholes may be weeping...but that may or may not be how any of this works.
Any tips or tricks I should know about? How does one go about tracking down a coolant leak?
