swinada
I tried to put some of these suggestions into pictures so I can envision them a little easier. The drawings are not very professional, please forgive me.
And please correct me if I did anything wrong.
1. A heavy-duty battery disconnect switch from plus on one bank to plus on the other, operated by a smart operator. No voltage drop or power used anywhere, but if left on can result in both systems becoming discharged.
3. A solenoid from plus to plus powered from the ignition accessory circuits, which connects whenever the bus is in the "run" position. This assumes the alternator is running whenever you leave the key on.
