dzl_
As the title says. What do you drive and how does it fair offroad? What modifications (to the bus or to your driving style) have you made to improve its performance? What modifications do you hope to do in the future?
We've gotten stuck in our 50' driveway twice after heavy rain.
I was mostly dirt with a slight uphill as you approach the street. Laid in 15T of gravel last spring.
Off hwy is poor, off road is no.
Yikes, that doesn't bode well for us. We're headed down toward Sedona/Prescott and we boondock pretty extensively.
Hope we're not coming up on rainy season![]()
Yikes. We try to scout out with the truck when in doubt. Knock on wood we've been pretty lucky so far.Beautiful area! I am not much for guided tours but the Pink Jeep tours are the exception. I had a blast hanging out in Sedona, Jerome and Prescott.
I did have a bit of trouble on one of the "scenic drives". I can't remember the nam. I asked the visitor center if I could take my bus ? They said " No problem".. It wasn't a problem until the road dipped into a gully and my back bumper hung up. No way I was going to make it. No problem.... Just back up untill you find a place to turn around. And that's what I did. What sucked was that the turn around was two miles behind me
Good advice. We're up by Glen Canyon right now and it's pretty sandy. Not too much red dirt, it's mostly sand which I'm assuming drains pretty well. We had a bit of rain but not a lot, and it didn't wreak havoc with the BLM roads. The red clay is what I'm worried about, seems like it would slick the tires pretty good. As long as we don't need to worry about sinking in while parked, we can wait out any rain...we're not on a schedule. Any thoughts on that (the sinking in)?Pick your spot wisely if you anticipate rain coming. Or don't plan on moving for a while. There are some places in that general area where the clay content is high. Adding rain turns it into a muddy slip-n-slide.
No problem.... Just back up untill you find a place to turn around. And that's what I did. What sucked was that the turn around was two miles behind me![]()
I've driven down dirt roads, up creek beds, and all kinds of bad roads and offroad. And, my 36 foot Amtran RE has been great.As the title says. What do you drive and how does it fair offroad? What modifications (to the bus or to your driving style) have you made to improve its performance? What modifications do you hope to do in the future?
Yeah, we had trouble when we were parked on wet grass...sunk into the mud just a little and we needed to be pulled out by tractor. This was at the storage yard, luckily, where they had equipment to tow us out. I think I remember Dreadman had a post about getting stuck up the the hubs in mud. We'd like to avoid things like this!Seems like most people don't understand how quickly a bus goes from moving to stuck.
Don't stop or go super slow forward momentum is your friend.
Some of the modifications (short of a full 4x4 conversion which I'm not inclined to do unless I get a cutaway) that I would consider to improve offroad capability are:
- More aggressive tires. Not full mud terrains but some AT's would probably be a big improvement
- An ARB selectable locker or Detroit TrueTrac limited slip if there were one available for my axle
- MT653 Transmission (the granny gear would be useful as a sort of "2-low" offroad)
- Distributing weight evenly and making sure sufficient weight is over the rear wheels.
- Possibly switching the duallies for single rear wheels (there are definitely pros and cons to this)
- Tucking low hanging parts, lines, etc up above the frame rails, (and if I were ambitious removing the bottom step and replacing the door)
- Consider a winch, or at least some good manual recovery gear (recovery strap, shovel, traction aid)
I do have a detroit locker in mine. Makes boat launch ramps nice and easy, including gravel/dirt ones.
