I understand the basics (I think) regarding why it's generally ill-advised to idle diesel engines for extended periods.
But how long is too long?
Is it a 'some damage is done no matter how long you do it, and cannot be reversed' type of thing?
Or is more that if you make a habit of doing so, you'll eventually create build-up that operating at load the rest of the time can't reverse?
I ask because I'm making small fixes to my air system that necessitates me running long enough to build up pressure a time or 3. Is there any harm in just letting it sit afterwards, or should I run it afterwards long enough to get up to temp? The latter would be a real PITA considering its in-construction status, but I want to do whatever it takes to take proper care of the powertrain.
/Really Stupid Question
