middlenamesparkle
- Joined
- Dec 21, 2017
- Posts
- 14
Pretty straightforward, curious if making a lighter weight bus will improve gas mileage.
Not by much.
Most of the diesel burned is used pushing air out of the way, and weight is a fairly small factor.
Weight reduction will improve MPG's if all else remains the same.
But...unless you get rid of a ton or two, you probably won' notice any difference and even then it will be relatively minor. Where it will show up...is on hills. Just a few degrees incline requires much more energy hauling anything up against gravity and a lighter load will require less energy. On flat land, moving air will be the energy sucker. A combination of losing a little weight (which we all could use) coupled with some improved aerodynamics could actually show up at the pump.
Truckers are all about economy, so you will see some good tricks there. Alloy wheels, wheel disks, aluminum trailers, trailer side skirts, truck side skirts, cab extenders, aero bumpers, aero mirrors, roof caps and even aerodynamic mud flaps.
Why?
Because when you travel a few hundred thousand miles a year...a mile or two per gallon puts money back in your pocket.
Funny thing with truckers though. They will spend a few thousand bucks to save a hundred pounds of weight or reduce drag by a percent or so...
...then add three hundred pounds of chrome and bling back on the same rig!
Omg. Thank you all for your answers!! I’m not planning to put a whole lot in my bus but didn’t know if it would be a poor choice to use old school lockers for storage.
