Maybe a kind admin will sticky this some day?
Tools Required
Sounds like a lot, but tool-wise most of you readers probably have a lot of this lying around. Fiberglass fabbers are famous for re-using all kinds of things in a pinch. When the epoxy is just about to set up on you, you'll grab anything to spread it if you can't find your squeegee. Try to avoid grabbing your credit card!
Tools Required
- Rubber squeegees. In a pinch, you can cut a pair from a coffee can lid - that soft plastic is about the right strength. Round the corners so they don't drag. It needs a smooth edge.
- Wide popscicle mixing sticks. eBay, $4.
- 2" wide Disposable "chip" brushes. Harbor Freight, $12.
- Disposable scissors. Harbor Freight, $0.99. (Get a few!)
- Mixing cups. Make sure they have NO wax - those sold for "hot" applications are fine. I like the wider, shallower ones and usually get the 36-pack of 12oz soup cups from Costco for like $9.
- Hair dryer. Do NOT try to use your wife's! Walmart, $10.
- Nitrile gloves. Harbor Freight, $9.
- 3mil plastic sheet, on a roll with no crease. $20 online, but one roll will last you forever.
- Dremel or (better) Black & Decker rotary tool. You ought to own this anyway.
- A few dozen sanding drums and the little raspy cutter thing - the one they sell for drywall.
- 12-pack of bi-metal hacksaw blades. No hacksaw required, just the blades. $9 at Home Depot. Cheaper at Harbor Freight but I think they mean a different pair of metals because they don't last nearly as long!
- 100-pack straight edge razor blades. Harbor Freight, $4.
