SmoothSailing
- Joined
- Oct 26, 2023
- Posts
- 11
Hello all, a little over a year ago I picked up a completed conversion. Only recently have I been able to use it, and what I have discovered is that the original builder seems to have wired the AC hook up incorrectly.
The system is a simple shore power plug directly into a conventional sub-panel with 4 breakers.
- There is no inverter in the system
- There is no generator in the system
Currently this is what the panel looks like (pic attached)
Problem: My understanding is that the bonding of the neutral and the ground wire as shown in the attached picture, is unsafe, and that this bonding should only occur at shore source.
Solution: My plan is to buy an additional isolated busbar, then screw it inside the panel and hook the main ground form shore to it, and then route all of the ground wires for each breaker to this isolated bus bar.
Is this a safe and correct way to wire the setup?
Thank you so much for your input!
