Diesel Dan
I'm curious how people have mounted water and fuel tanks underneath their buses. My bus' stock fuel tank is mounted directly to the main center chassis frame by a huge 3" tubular steel bracket that is essentially suspended other than that one side that is attached to the frame. No doubt it is soundly engineered due to the size of the metal, but I cannot use that same strategy to mount my auxillary tanks.
I will likely use 55 gallon drums, or something similar for all my water and fuel tanks. The chassis frame obviously offers a solid mounting point for one side, but I don't see any real substantial metal to mount the out-side to. Obviously people are tying into something, and it works, so maybe I'm trying to over-engineer this.
The best approach I can think of is to bolt angle iron across several floor beams tying in to as many points as possible over the full length of the barrel, and then having either some sort of metal straps, or a suspension system of vertical angle iron or threaded studs coming down from the attached angle iron.
Are those floor beams strong enough to support 400+ lbs of water or fuel in a steel 55 gallon drum?
