How to secure my bus?
It's a very nasty, caustic substance that kills the cells responsible for horn growth.
Nasty crap, but not nearly as nasty as getting gored.
If you've removed the lines that far, why not get them out of the cabin and back at the motor with your coupling. I would used the heavy duty hose clamps that came off the heaters, they are way better than standard screw type hose clamps.
I've actually been meaning to swap out the standard clamps I used for this, but a few days ago my garbage pile was robbed and they took the heaters (along with those clamps).
I wanted to delete my heaters in the way you suggested, but I have no experience with engines of any kind and I couldn't figure out how to do it (or even how to open my hood) whereas the lines to the back were just sitting right there. Next time in the shop I'm going to have my mechanic do it properly - I assume it's a fairly trivial task for someone that knows what they're doing.
Dehorning paste only is an irritant. I have a gate that people would climb over ignoring the keep out
Posters- I smeared old nasty grease all over that top rail. Left many marks. Police would say he probably got acid in his hands from stealing batteries.
The window does not lock. but to get into the bus easily you must pop the pivot arm "AND" remove the locked hasp. I got ok low grade locks abus hasp and disc lock. not great but better than masterlock for sure :)
the hasp is the security the window and strap is how you open the door once you remove the lock.
All the thief has to do is watch you 1 time or figure it out by looking thru the windows.
He could also just bust the window on the door and pry the lever back with a 2x4
