Elliot Naess
I'm no expert, and this may not be all you need to know.
But here are photos of the two most common Allison automatic transmissions in
older school buses. The side mounting pads may be a good clue. On my buses
they were not used and easy to see.
Here we go:
AT545. Note simple mounting pad with two holes above each other near the front.
Nothing on oil pan.
MT643. Note complex mounting pad with four mounting holes.
Temperature sender on oil pan.
The MT643 is the one to have. It is stronger and the converter locks in 3rd and 4th.
(Edited with this additional info):
AT545 -- max 235 HP, 445 lb ft, 30.000 Lbs GVWR; no lockup, SAE 3 bolt pattern.
MT643 -- max 250 HP, 640 lb ft, 73.280 Lbs GVWR; locks in 3rd and 4th, SAE 2 bolt pattern.
More info here: http://www.industrialautomatic.com/html/onhiway.htm
