Humidity and ventilation
asquarecan
Feb 5, 2019
33
Portland, OR
Hey guys!
So I had a conversation yesterday with someone that got me thinking. Not having an experience with RV's or trailers I did not think too much about this.
If I spray foam the bus am I doing to have to worry about humidity/moisture inside the bus?
Also are you guys running an exhaust fan of some sort to keep moisture or humidity down?
Thank you as always!
It depends on climate and how much moisture you add to the environment.
I have lived in a bus with spray foam insulation in the Seattle area in the Winter.. FWIW in a 5th wheel trailer as well.
Just breathing adds a fair bit of moisture to the air. Showering and cooking on a propane stove a lot of moisture. When that moist air hits cold surfaces it will condense and create problems.
Living in a cold damp climate I found a dehumidifier to be a necessity.
Living in Arizona in the same bus through the winter moisture was a minor issue. Cracking a roof vent took care of it.
The spray foam insulation does not contribute to the moisture trouble.
Regardless of insulation, or even lack thereof, you're still in a big steel tube that will not breathe with everything closed down (assuming leaks/gaps addressed). Ventilation will be required. That could be opening a couple of those big windows, exhaust fans, etc. But I don't think insulation would have much if any impact on that need. Either way nothing's getting in or out through the skin. Like Steve said, you & the environment are what determines the moisture in the air. Insulation will affect temperature, & temp will affect RH (relative humidity), but that's not really what we're talking about here.
The dehumidifier that worked best for me was a Whirlpool brand that I bought at Home Depot on sale for about #120. It had a drain hose connection that eliminated the need to dump the collected water 1-2 times daily.
good advice from your pnw rainforest!
:biggrin::biggrin: I live in the desert now.
I spent a number of years N.E. of Seattle in a spot that gets quite a bit more rain than Seattle. We were in a canyon with what they called a creek in the back yard. It was one of the wettest places I have been. Once we finally got electricity, we ran the dehumidifier 24/7 about ten months of the year.
Now I live in the part of Washington that you don't hear about. Sage brush and rattlesnakes are easy to find.
