cadillackid
so you want to go from the Outlet of the pump to the inlet of the heater...
if the pump inlet is forward of where your heater will be.. ie rear engine bus and the engine pumps coolant first through the rear heater and then sends it forward into the booster pump.. then you would make the INLET of the rear heater be from the engine compartment.. and the OUTLET of the heater would go towards the inlet of the pump..
in a front engine Bluebird bus, coolant typically travels in the right side heater.. then into the driver heater. then out of the drivers heater and into the pump.. then out of the pump and into a MID heater (if equipped).. out of the mid heater and into the rear heater.. then a long line all the way back up front into the engine inlet..
your jegs heater inlet should be connected to the hose with the pressure.. ie coming from the pump.. the outlet of the rear heater would then be the return to front..
all the heater loops begin and end at the engine..
