Off-season sports
- Joined
- Jul 24, 2023
- Posts
- 5
Hello I'm new my name is Randall. Have a 2004 thomas transit bus mercedes 996 engine rear motor. The hydraulic cooling fan motor went out, and I can't find one. Please help.
I'm sorry my motor is a mercedes 906.Hello I'm new my name is Randall. Have a 2004 thomas transit bus mercedes 996 engine rear motor. The hydraulic cooling fan motor went out, and I can't find one. Please help.
Do you mean the radiator fan's hydraulic motor, or the diesel engine itself (that really doesn't matter in this context)? It causes less confusion if you refer to an internal-combustion engine as an 'engine' and the electric motors and hydraulic motors as 'motors'; these two terms are not freely interchangeable.I'm sorry my motor is a mercedes 906.
I have a 2006 Thomas HDX w the MBE906250 which also comes w a hydraulic motor for the radiator cooling fan. I've replaced the motor, but the problem seems to be the control valve not putting the fan in high mode. I can't find a replacement control valve. Does anyone know if its possible to bypass and have it operate at high speed 100% of the time?
What make/model of solenoid directional control hydraulic valve do you have? My bus's Danfoss 7WA110-2 valve partially restricts the flow of hydraulic fluid to the fan motor at less than 195F, then allows full flow above that temperature. The valve's default mode is fully-open; for it to restrict flow requires its ground wire to be grounded through the temperature switch that opens above 195F. The valve is always connected to 12VDC positive; only the switched ground actuates the valve. My bus has a self-resetting CB that supplies power to the valve: has the CB (or fuse) in your bus that powers the valve tripped or blown?I have a 2006 Thomas HDX w the MBE906250 which also comes w a hydraulic motor for the radiator cooling fan. I've replaced the motor, but the problem seems to be the control valve not putting the fan in high mode. I can't find a replacement control valve. Does anyone know if its possible to bypass and have it operate at high speed 100% of the time?
I suggest you start looking for more of those valves now while you have time, because if (when?) your valve goes tits-up, if you don't have a spare you'll need to change the entire block assembly that the valve and solenoid are part of, and that will be a royal PIA. Amazingly I found on eBay some years ago, more through luck and chance than anything, what may have been the last three valves like mine in the USA, so I bought them all! I changed out the original one as a preventive measure, so now I have two spares "just in case". I have a tendency to do this with other things as well, accumulating a small treasure-chest of spares for my bus made by a company that went out of business more than thirty years ago.My CV is a Danfoss 1090757 which I've found is no longer manufactured. This is very helpful. I hadn't considered a fuse. Thanks for the info!
