nikitis
if i remember rifght the B and C was federal vs california and I think canada got the california programs as their standards were more restrictive than US federal.. I did a lot of experimenting with these.. and found that the codes in the 3 Box 94-97 manual did a good job of representing the T444E and that the power levels seem to be pretty cnsistent through all model years.. an AT545 should be able to take a B or C210 rating.. if it slips then that AT545 is not long for this world... the rating on them was high enough that 210 and the standard torque rating was well within the range of a 545...
Maybe, except that it just did a 1600 mile run this week with no slippage running at 2400 RPM during most of that run. Seemed fine to me.
the only exception to these EFRC codes might be the 02.5 and up as they all (low and high torque) used the same turbo.. ironically similar to the ford 7.3 turbo... that said im running a 2004 ECM in mine and used the 2004 VIN on it.. when I swapped the VIN back and forth (I had a NAVKAL subscriotion so I could download the calibrations from navistar based on VIN) I found very little difference in performance, boost or EGT from each other until i got up in the 230/250 range settings.. then i noticed differences...
NavKal is a connected service with navistar generally used for changing protected parameters through the dealer and getting the latest calibrations.. I changed the VIN and engine serial number using the god mode servicemaxx...
My ECM was updated to accommodate the new VPM Replacement. It's also possible that they uploaded later tunes for the engine especially if they knew there wasn't any hardware difference to make it operate better. I would of gotten any updates they made or bug fixes. I think i'm gonna try the 2161 EFRC here soon which is for the A195 1994 year engine. I think I have the 1994 Year engine because the stamp on the body said was manufactured September 1994, so it's likely a first year model. 2161 is the 195 tune and highest listed in the T444E EGES manual for 1994. They may have accounted for Transmission slippage potentially who knows and may be better for my situation?
