Elliot Naess
I have gotten the carburetor jetting sorted out, but my 1981 MV404
still fails smog check. It puts out too much hydrocarbons at 2500
RPM. The source of the problem seems clear enough: the #1 cylinder
is not firing properly. It doesn't show up on the scope, but when the
analyzer cuts out each cylinder, the #1 does not drop any RPM.
Of course, we verified this the old way also by pulling the plug wire off;
no RPM drop. So I've been driving around on a 7-cylinder engine -- well
a 7 1/2, or so.
We switched the plug with another; the problem stayed on #1 cyl.
The plug wire measures 10.000 ohms, just like the others. The inside
of the distributor cap looks good. Compression is 120, just like
the others.
What da heck??
Could the ignition system be failing to fire one cylinder properly? It is
an electronic distributor. There is a "star wheel" where the points cam
would be on an older unit.
How about the governor system? I have no idea how that works. There
is a little electronic box on the firewall that says "electronic governor
control", with three wires. What does it do? Does it pull the carburetor
back or does it kill spark?
Help! What are we overlooking?
a 7 1/2, or so.
the others.
What da heck??
