So! Yesterday was my first attempt at having a 'build day' on my bus, which meant driving across town to the rv storage where I'm keeping it, and then driving the bus to Home Depot to set up in their parking lot to work.
My first task was to finally install the door lock I'd bought two weeks ago and failed to install. Again, it was a failure - the instructions were either incomplete or inconsistent, and I ended up drilling the exterior hole too large for the the cylinder to stay in place. The instructions called for a 1 3/8" hole, I drilled a 1 1/4" hole, and the cylinder ended up being only like an inch.
Brainstorming solutions, I opted for a small piece of wood to cover the hole, and to re-drill. Went in the store to buy the wood, screwed it to the outside of my door (making four new little holes in the metal), only to find that my *smaller* hole saw didn't have enough reach to cut completely through the wood I'd bought. So, rather than buy another piece of wood or another hole saw, I decided to put the 'door lock project' on hold again, and try the next task: removing the seats!
I'd seen a good technique for removing the bolts using just an impact driver and a prybar, and since I don't have an angle grinder yet, thought I'd give it a go. The idea is that you loosen the bolts enough to get the prybar under the seat frame, then use the upward pressure to hold the nut tight against the underside of the bus while you continue loosening the bolt. Simple enough! The impact driver worked great for releasing the bolts and getting them started, but I wasn't able to get the prybar under the seat at all. So, after about 30 minutes with the impact driver, a useless prybar, and even going under the bus to see about removing the nuts from below, I gave up on this task as well. Looks like I'm in the market for a good used angle grinder after all.
Overall, a disappointing first-day on building the bus, and hopefully not a sign of things to come. Next time I go out I know I can at least start removing the seat portion of the benches (held on by simple phillips screws from below the frame), and get those prepped for the dump. It's not much, but it's a start.
Also, I decided to find a large-diameter washer I could use to hold the lock in place - small enough to hold the cylinder but large enough to cover the original oversized hole. The smaller holes I'll just fill with some bondo to seal them from water. The washer should show up today and I can pull the wood off and install it next time I go out, which I'm planning for tomorrow.
