Help with Blowby
So I am new to diesels. We converted a 1999 International 3000RE to an RV. I am good with cars and pretty handy, but Diesels are a new animal to me.
My problem, I noticed a significant drip of (what I thought was oil, but turned out to be coolant) coolant, coming from the compressor/engine block fitting. Before I found the leak, we were remodeling the bus, and I would let it high idol for a while to keep the motor functioning and to look for problems (thus I found the leak). By this time the bus had run low on coolant, and I developed an air lock at the thermostat which would stay about 140 degrees until I shut off the bus and it would jump to 190 degrees.
I then did a flush and vac fill of coolant and the temp gauge problem went away as it would gradually go up to 190 and stay there. I also bypassed the heater lines running through the bus and attached the coolant hose from the pump to the top of the engine near the thermostat. (just bypassing the heater loop that ran through the interior of the bus). I used the extended life, High mileage Red Coolant.
As I took the bus for our shakedown trip, I noticed that when I pushed the throttle down there would be a puff of bluish smoke from the tailpipe. (About 2/3rds of the way into the mountains) But nothing when at idle. Once the shakedown trip was over and we began to warm the engine to come home, I noticed quite a bit of white smoke coming from the breather valve that I didn't notice before. This happens as the engine warms up, however I do not notice any of this coming out the exhaust. I have also had the engine parked and when I rev the engine I do not notice any abnormal exhaust coming out of the exhaust pipe.
I have noticed the coolant level very slightly drop over a few hours of use. (maybe 1" or 1.5" in the reservoir. I have also not noticed any leaking or dripping of. coolant. The blowby tube still puts out a weak constant puff of white smoke, one that hardly makes it to the ground if at all on a calm day.
I'm trying to figure out if I have damage to the engine.
1. I would think if there was an issue I would have smoke coming out of the exhaust as well.
2. The oil when checked is 1/4" over full, but not diluted feeling. And it smells like burnt charcoal and is very black and not runny on the dipstick.
3. Is there supposed to be a normal amount of blowby for an engine with 236K miles and 12k+ hours on it?
4. Our shakedown trip was at an elevation of 5,000 feet up to 9,500 feet and back down to 8500 feet within about 1.5 hours. Coolant level on the high grades went to 215 and stayed there Based on Dash reading) and would quickly drop back to 190 when not climbing. Could this have caused an issue? I tested the thermostat when replacing the coolant and it is set to open at 190 so I assume the dash reading is correct as the temp settles at 190 in normal operation.
5. Last thing I can think of is, if we moved our air intake screens down to the engine bay doors from being horizontal to the windows and removed the air scoops, could this be causing a problem? Should I reinstall the air Scoops down onto the engine bay doors where the intake screen now is?
Any advice would be great!.
I am trying to understand and Diagnose the best I can so if I have to take it to the IH dealer, I want to know if a rebuild is necessary, or if what I am experiencing is normal for a 1999 DT466E.
