Inserting outside skins
adic27
May 15, 2017
573
Houston TX
From the looks of it there is nowhere to insert the sheet metal on the bottom, as far as I can tell.
Anyone else's bus look like this?
The 3rd pic is with the window out
Thanks
if you insert it water might get into it also. just make sure it has a good edge on the bottom , remove any rivets that hold it away from the existing panel seal then fasten it with the upper overlapping on the outside of the bottom so water will not get in
