adic27
Did any of you come across the inside wall panels to being kinda tack welded? I'm referring to the sheet metal material under the windows. I took all the screws out, and one rivet?
, and even had to deal with a few stripped screws just to find that something is keeping the panel intact. At first, I thought it was some kind of glue or seal or maybe even hidden screws but discovered its like tack welded at the top of the sheet metal panel. I have to use vice grips to pull up a metal flap right under the windows to get to the sheet metal so I can pull it apart but I think pulling the metal flap up is going to make it easy for water to get in when it rains.
Anyone have to go through this? How did you go about it?
