install roof rv ac on bus modifications
May 27, 2023
9
I have a 2001 International 3800 bus, intend to install standard roof type rv ac unit. most of them fit in a standard 14x14 inch vent hole, the existing emergency hatches are larger, do I leave emerg hatches alone, and cut new hole, or modify one existing hatch, if modify, tips on how you did it please.
Thanks
Convert Hatch to AC
I converted the rear hatch from a 24" square to a 14-3/16" square to add a rooftop AC/Heat/Dehumidifier.
We installed the unit before completing the demo to stay cool/warm while we work.
For more photos and detailed instructions, please read the tutorial 'Convert Hatch to AC', below⤵
Nice work and professional as always! Is that Houghton as quiet as they say they are? I went with a single Dometic Penguin II in the center of the coach. The front and rear are the old Dometic split systems. Rest of the roof is all covered in solar panels
AC
Personally having used my AC mainly for the dog, I would reconsider a normal rooftop and get a mini split. They are more efficient energy wise and cool way better. Get a well known brand.
minisplits are great if you have the room for the outdoor unit and the indoor unit..
one of my friends used 2 roof airs because he wanted to keep his original bus A/C for when driving and those units are in the bulkheads.. he frequently drives through the desert southwest and the likes of texas / louisiana, etc in summer where minisplit wouldnt touch the heat while driving.. roof airs made sense as they are non intrusive.. he only uses solar for his low voltage appliances.. when he is parking for the day, he is parking in as shady as spot as he can get , runningthe genny and the roof airs..
RV roof air units are also easier to install, even with fabricating metal and supports.. minisplits you really should have HVAC tools, and knowledge of using them or plan to spend $$ and hire out the flares, vac, and test of the system..
Houghton HVAC
I remember you had considered buying a Houghton and Furrions for your old Mesa Bus.
attachment.php
As far as the noise level.
Yes, it is as quiet as they say. We have a pair of smaller Dometics in our 30' camper and a Coleman in our 16' camper. The Houghton unit moves a tremendous amount of air yet it's much quieter & energy efficient than the others. I have, more than once, forgotten to turn if off when I leave.
I ended up buying two Furrion units that went uninstalled with the bus to the new owner. I don't think they had the Houghton units in stock. (Covid era) I have heard very good things about the Houghton a/c's. I went with the Penguin II on this bus mainly since I wanted it to be as low as possible. Exterior aesthetics were priority first second to cooling and finally amperage use. The Penguin cools very well but not enough when the coach was dark brown and 100º out. Working on a possible install of this undermountac.com 48v unit. I have been in communication with the owner. I have a decent battery bank to handle this and more. We are thinking of adding another 30kw of batteries for a combined 60kw. This would give us 3days of 2 a/c's running non stop along with all appliances. Generator and solar to supplement when needed. I think Truma has a super quiet low profile unit that they are going to be selling to retrofit crowds.
