ChrisLifts
- Joined
- Dec 17, 2021
- Posts
- 40
When installing windows, a frame needs to be constructed on the interior of the bus for the window to have something to sit in. I believe the most ideal way to do this would be to create a frame out of square tubing and weld it to the hat channels. Is there a downside to creating a wood frame instead? It would be much easier if I could just make a frame out of 1x2s for example (2x4s are probably way too thick) and attach to the hat channels with self-tapping sheet metal screws. For those of you that didn't roof raise or re-use the original bus windows, how did you frame in your new windows?
Thank you,
Chris
Thank you,
Chris
