Cool chart, thanks for sharing. I'm going to have me a closer look at that.
Side question: what are you guys doing to cut thermal "bridges"? Spray foam is fine between the ribs, but I have to attach walls TO those ribs - what's the best way to deal with those areas?
I'm using what I call wood strapping.
I run strips of wood 3.5 inches wide by 1.5 thick across the upright support ribs, running horizontal.
I spray foam the 3.25 inch space behind the strapping till it's flush with the surface of the strapping.
Then I glue 2 inch thick sheets of rigid Styrofoam to the surface of the spray foam and strapping.
Everything you mount on the inside screws into those ribs every 16 inches from the floor to the ceiling.
This provides a true thermal brake.
Now here is a variation of this method.
Do the strapping the same, but glue the rigid Styrofoam to the surface of the strapping before spray foaming the space behind.
Now use pour foam, poured in batches from the top.
This bonds the foam to the inside surface of the rigid Styrofoam sheet far better than any adhesive can.
This method also skips the step where you have to shave all the over spray of the foam.
Over spray is the spray foam that expands beyond the surface of the strapping. Unless shaved, we cant glue the rigid Styrofoam in place.
For the fellow skoolies that have used spray foam them selves, they know this is a massive amount of work, And tremendously messy.
A hybrid system. We would skip the plastic, and substitute the plywood for the rigid Styrofoam, and back it with the plywood till done curing.
Skip to 5:00 to see a fast way of cutting.
Nat
