I have an Airporter style shuttle bus a 99 Ford E450 aprox 23' long.
It is my second bus, the previous being an 88. It has the rubber type floor with the alum channel inlaid into plywood.
I have been looking for some definitive advice on how to insulate the floor and prep it for peel and stick luxury vinyl plank. I have purchased the flooring, got it on clearance, combined with a no tax special and a discount for being a veteran.
Pulling up the vinyl floor and the alum channel is a bitch. The question is too, what kind of insulation sandwich do I make?
One approach would be to lay down a grid of 1x1 or 2.2, put bubblewrap reflectix in the bottom and then rigid foam, topped off with a .75" acx or particle board. Final layer being the peel and stick.
I could just leave the rubber flooring and go over the top of the rubber floor and alum with a grid, then same as the other.
I question the need for reflectix at all in the floor?
I live in the moist puget sound, but try and get the bus out on the hiway for an hour or so, to keep the oil flowing in the engine and dry out the interior.
Anyway, would love to hear your advice about insulating the floor. The primary goal is a good surface for the peel and stick and the next to insulate the bus since the walls and the ceiling will be insulated as well.
Thanks
Thanks
