paulnack
Hey all. I've been racking my brain on thermal calculations, and I thought I'd externalize my madness and include you.
After doing some math, I realized just how severe the heat transfer through the driver section will be, compared to my insulated walls and floors. Here are some numbers to give you an idea:
2.5" spray foam walls and ceiling: 22.5 watts/ deg C
3" rigid insulation floor: 6.8 watts/ deg C
9 double-pane RV windows: 16.4 watts/ deg C
Windshield, door and driver window: 34.8 watts/ deg C
Dash and driver floor: 67 watts/ deg C
This is for an 11 row front-engine flat-nose with an 18" roof raise. You can see my efforts to insulate in the list above. I am assuming the exterior surface is at ambient temp and I am excluding heat from solar radiation, because my roof will be shaded by decking/ solar panels. Also, for the dash area I assumed an R-value of around 0.5. With all that being said, it will take around 10,000 BTU to cool the interior ~25 deg F (I live in FL).
When you consider that mini-splits should be oversized by 150% to 200%, I'm looking at an 18k BTU system. No thanks, I think I can do better. Obviously, the point of focus is the cab area. Not much can be done about the windshield. I could install a new door, but I really want to keep the original. So my question to you all is:
What have you all done in an effort to insulate your dash areas??
Also, if anyone is interested in my thermal calcs (including solar radiation) I will be happy to share more detail.
