SassyLass
I am in the planning stage for the Skoolie that has yet to be purchased. I plan to gut, insulate for a thermal break, and eventually raise the roof. Goal is 4-season full-timer, multiple climates, with winterized everything.
My question for all of you- what brand(s) and type(s) of insulation did you choose for each situation and why? If you can link to the specs even better!
In my research so far, I am finding that many are:
1.) highly flammable and the mfg 'requires' a flame resistant covering such as gypsum board for safety.
-I really don't want to add gypsum- is there an alternative?
-have you found a type/brand that is flame resistant without adding an additional barrier?
2.) several warn about potential wicking and/or absorbing water. This concerns me because of potential condensation when the exterior sheet metal is exposed to the elements- especially within the ribbing that has no thermal break to the exterior.
3.) for all those spray/pour foams that require moisture and air to cure- is that moisture then chemically bonded with the product 100%, or does is always contain moisture that is now in contact with your steel?
4.) pros and cons of foams (spray, HD & LD) especially those that use specialty gases in their manufacture or application process. I see some require an air barrier to prevent off-gassing and degradation of the product/R-value.
5.) shrinkage and expansion - I see many that have up to a 2% variation, and tests that find gaps between sheets caused when expansion damaged the edges with pressure, then cold contracted. This would totally defeat the a thermal bridge.
My concerns about fire safety stem from surviving a fire in a mobile home (started at a wood stove chimney outlet) The fire chief commended my quick emergency reactions, and told me that I only had 18 minutes before it would have been fully engulfed because of the construction materials. He said they didn't expect to find it standing when they arrived- I was 30 minutes from the station.
So- fire safety is very important to me. Been scared sh**less once, dont want to try for twice. I know there is no perfect solution in a skoolie, but I'd like to get as close as possible.
What say you all???
