The_Stuff
Villa Estate 392FLFB
i will have to hunt for one of those perhaps. sucks running out of propane. It happened again last night. was frying up ground beef and then it just... stopped lol.
It's in the concession trailer on a 20lb LP tank. But I have also used it in my house (1 lb disposable bottle) during power outages. No matter what you use to heat with, you need a CO detector, smoke detector and an LP detector (if you use any LP). Some are combination units although I think the LP detector is a stand alone alarm. These are inexpensive and can be bought at any lumberyard/hardware store. I prefer the battery operated ones. Being able to put the shrieking thing outside because it went off while you are cooking is a blessing (I can't help that I like to read while I cook) and you can install one anywhere without worrying about running electric. The First Alert CO/Smoke alarm I have is a bit touchy. David was grilling hamburgers outside and the light breeze blew a little smoke from the grill inside... silly thing went off. It's happened a few times.
If you are planning on using the MR Buddy to heat with often, then you may want to plumb an interior connection (put a shut off valve on the connection) so that you can use a LP gas hose to the heater with. The regulator is built into the heater (you are threading the disposable tank or LP hose into the regulator). That is far cheaper than using the very pricey disposable tanks.
Can you link to a battery powered LP detector that you like please? I just can't find one.
Well I usually start with a good, old fashioned google search. All the searching I have done here and in the further reaches of the internet have turned up sniffers that you use intermittently or the 12V hard wired models.
I would ideally like to find a battery powered detector that can be easily installed, like a CO monitor or smoke detector, but it seems those may not exist. Your post gave me hope, though.
You're just not trying hard enough. The ones that plug in the wall are 12V, they don't need to be plugged in with the battery back up.
Here's what you're looking for.
https://www.amazon.com/PANGAEA-Digi...ocphy=9011028&hvtargid=pla-1321336445911&th=1
How long have you found the battery to last? I have come across plenty of those in my searches that apparently aren't "hard enough". I just didn't think a backup battery would last very long. If you have found that they do then I'll certainly just buy one of those.
Thank you for the kind advice.
I suspect the ones that plug in the wall just convert 120V to 12v. The one I linked is battery only, you think the battery in it lasts longer than the battery in the other?![]()
