tomas_maly
I plan on being in upstate NY in the winters (lows ranging from -5 to -25 F), and want to plan for insulation appropriately.
I have some polystyrene insulation, about 1 inch thich, rated at R-6.5 that I'd like to put on the interior of my bus (7.5 x 29 ft interior). I'm wondering if this is enough for colder weather, assuming I have heat on (efficient woodstove)? Or should I go with slightly thicker insulation? Maybe a different material?
Would it make sense to try to insulate the ceiling? I happen to have a bunch of R-11 white fiberglass insulation (extra new floor insulation meant for an old mobile home), and wasn't sure if it helps that heat isn't lost thru the ceiling. I am 6'3" and so it would be unfortunate to lose 2 inches at the ceiling area, though. There looks like the ceiling and the roof have a cavity in between them (all the electrical appears to go through conduits immediately above the windows) and I'm not sure if it's worth the effort to try to remove the ceiling (not sure if they are rivets or torx bolts) and see what i can stuff in there. Or maybe it's easier to remove the roof off and do it from the opposite direction?
And then what about the floor (seems easier to insulate, from the underside)? Heat obviously rises, so maybe that's not a concern. Either way I'd probably have polystyrene skirting around the vehicle to prevent drafts to freeze the underside. I'm assuming a woodstove nearby a water tank (underside) would radiate heat and largely prevent the water tank from freezing assuming the interior felt comfortable. Or do people add insulation (can't hurt, maybe as a precaution), heat coils, etc around the water tanks?
I plan on utilizing solar panels so I'm not sure if I can do much in terms of placing anything with insulating properties on the roof.
I was thinking of removing about 1/2 of the windows (for heat retention) and somehow filling them up. Or is it common to just keep the windows and seal them shut, paint over them, etc? I'm assuming if they are removed then that means a bunch of metal work on the exterior, and added sheet metal costs (windows vary from 3'x2' to 2'x2', and I've been quoted about $36 for a 4'x8' sheet of 22 gauge from Fazzio's in NJ). I don't think I could scavenge that much metal. If I kept the windows in, the problem is that once I close it all up from the interior, I can't remove the windows since they come out from the inside. Such as if they get cracked, broken, etc by accident.
