I've installed a Coleman Powermate 6250 (5000 watt) Genset under the bus and would like to build a quiet box to help out a little with the noise.
The genset will be operated with its hatch door open to allow air in and heat out. I am also thinking I might leave the bottom open for the same reason.
The muffler will NOT be inside the quiet box. I have a bit of exhaust pipe that I can put on the muffler outlet when I run the generator. This will extend the exhaust beyond the side of the bus and will aim the exhaust down towards the ground.
On hand I have some pink stuff 1/2 thick foam insulation, some 3/8 plywood and some 22 gauge mild steel.
To insulate against heat and noise, my guess is to put the steel to the inside followed by the pink stuff and plywood on the outside.
