Stu & Filo. T
Hello All;
I'm looking at my next step which is installing a Intercooler on my 8.3 Cummins that's installed in my Crown Pusher. One thought I have is building a scoop out of Fiberglass that starts at the roof with a intake that's about 8 inches high & say 3 ft wide that tapers down to about 2ft wide at the bottom, the scoop could run down the back of the bus & stop just above the cooling vents for the eng compartment. My thought process here is ,Positive Air Pressure scooped up at top of bus & as it narrows increases pressure in front of Intercooler but negative air pressure at exit of scoop because it would be down in vacuum area behind bus would pull air thru.
option 2; Mount a box or cooler inside eng compartment install Intercooler inside then when traveling fill box/cooler with water & a couple slabs of dry ice.
