Booyah45828
I'm in the process of mounting an on board generator underneath the bus.
I scavenged an OTR truck apu, which provided me with a yanmar diesel engine w/ alternator and a sincro 5.2kva generator head. I combined all of that with a variety of other parts and now have a 4kw diesel generator. It's liquid cooled, belt driven, and has a 12v/40amp alternator. Perfect for my uses. Not overly loud either when muffled and the air cleaner installed.
Those of you that have mounted a genny under your bus, what have you used for sound deadening/heat blocking. I was looking at dynamat, but I'm not sure if I'm willing to spend that kinds $$ on something that I think is marginal. Anyone use anything cheaper/suggestions on it? It's going to be enclosed on the 3 interior sides with the radiator and fans facing the exterior. I'm keeping the bottom open to supply fresh air.
I was thinking of using some sort of mineral wool insulation and heat reflective mat between the genny and the floor. And then heat reflective mat on the sides.
Let me know what you've used and you're opinions on it.
