Starting work on the electrical system and I’d like to run the 24v bus systems while on shore power. There are 2 power distribution panels (pic of front included).
I already have a 100 amp 120 to 12 converter so I’d like to use that (pic included).
Can I just get another of the same converter and hook them up to the power panel to supply 200 amps of 24v?
Thinking I should connect the red of one converter to the 12v terminal and the other to the 24v. Common black terminal for both.
My assumption is that this will run the bus with no issue (need to get into the books and confirm amp requirements).
Will this also safely keep the batteries charged?
https://app.photobucket.com/u/romad7/p/c6197d17-0378-4713-b39a-e374b50a2899
https://app.photobucket.com/u/romad7/p/e0019cd3-9a50-4e85-b5b3-1336b7a38e64
