I have started building a tailgating bus with alot of great tips and ideas from this site. As soon as I think I have the electrical figured out, it seems to get that more confusing and was hoping for a little guidance. It has a 30 amp shore to a 30 amp 5 breaker panel. There will be 2 seperate outlet circuits, one on each side of the bus, mainly a 26-32" LCD on each side, 1 direct TV box and 30 amp converter and that is really it. All wiring is Romex 10/2 w/ground. There will be a stub out for a future roof mount A/C. No microwave, refrige, stove etc. I may plug a portable A/C into one side from time to time but only when on shore or generator. All lights will be DC. My main concern is the stupid inverter hookup. It is a cheap 1000 watt/3000 peak with 3 standard outlets on the front which I figured to be somewhere around 8-10 amps max. I considered a subpanel but thought it would be stupid since my wiring, minus the A/C, can all be powered by the inverter and would be very redundant. Thought about the suicide plug to backfeed the circuit but dont think that is the greatest idea. This bus will only be used during football season so it doesnt have to be as foolproof as an RV that jumps from hookup to hookup.
My question is, can I put a normal household switch at the end of one of the circuits and wire the inverter into the switched side? Then when I want to use the inverter, I turn it on and flip the switch to backfeed the circuit and the panel?
What do you do with the converter to keep it from running off of the inverter? My thought to this was to put this on a switched outlet with the switch right next to the inverter switch so when one is on the other is off. Is this needed?
To stop the dummies from flipping the switches, it would be in a seperate enclosed compartment with the DC fuses and also have a simple lockout on the switch itself to keep anyone that gets into the compartment for whatever reason from accidently hitting it.
