MollyCMo
The internet says most buses are 10.5 feet tall from the ground. Is this for a low-top, or a high-top?
Thanks everyone! I'm asking because I'm trying to figure out roughly how much headroom I'll have in my bus if I lift it to 13.5 feet, which I believe is about the max you should go? I want to go as tall as I can.
That sounds like great advice...I've also read on here that if you're going to do a roof raise, it's one of the first things you should do in the conversion, which makes sense. Do you really think it's a good idea to drive the bus for a thousand miles before doing any really conversion work to it? Or was that just a rhetorical comment? It makes sense, I'm just wondering if you really mean it, or the best way to go about doing that.13'6" is the maximum for highway use.
Having a tall bus, I wouldn't want to push that limit at all. I already scrape stuff with mine.
I implore anyone wanting to do a big roof raise to drive a bus for a thousand miles first.
