ShagNasty-SKO
Consumer Reports did a study in 2006 where they measured pressure loss of nitrogen-filled Vs air-filled tires over a one year period. They took 31 pairs of all season, automotive tires (H and V speed rated). One tire of each pair was filled to 30 psi with air, the other tire from the pair was filled to 30 psi with nitrogen. All 31 pairs were then set aside, outdoors for 12 months.
Their conclusion was that nitrogen does reduce tire pressure loss over time, but the reduction is only 1.3 psi.
Air-filled tires, originally filled to 30 psi lost 3.5 psi over a one year period.
Nitrogen-filled to the same starting pressure of 30 psi lost 2.2 psi over the same period.
More importantly ALL tires lost pressure, so consumers should check their tire pressures routinely regardless of the gas used.
The air around us, in our atmosphere, what we breathe and what is in most automotive tires is a mixture of gasses.
Air = 78% nitrogen + 20.95% oxygen + 1% other gasses ( 0.93% argon, 0.038% carbon dioxide, trace amounts of other gases and a variable amount of water vapor).
So, already all of the above claims are not true by 78% because going to pure nitrogen will only replace 22% of the tire’s internal volume.
The claims of improved steering, handling and braking, as well as reduced chances of tire failure and improved fuel economy are true for properly inflated tires regardless of the gas used to fill them.
Then there’s the claim regarding the reduction of internal tire oxidation because nitrogen is inert and oxygen is corrosive. I don’t think any of us have ever replaced a tire that had internal rubber decay because of oxygen corrosion. Although it is partly true –oxygen is corrosive-, your tires will wear out many times over before oxygen starts to damage the rubber material. If this claim were true and oxygen causes rubber corrosion that quickly, what about the outside of the tire? It is exposed to 22% oxygen even if you have pure nitrogen on the inside!
Some people also will tell you that tires filled with nitrogen don’t change pressure as much with heat as those filled with air, or that tires filled with nitrogen run cooler than those with air and that’s why most race cars including F1, Indy and NASCAR all use it.
Again, not true.
At the temperature (150 – 250ºF) and pressure (25 – 45 psi) thresholds found in racing tires, both air and nitrogen will act as “ideal gasses”, meaning that they will react exactly the same to temperature and pressure.
Oh, I almost forgot. There are those that claim that since nitrogen is lighter than air you’ll save weight and have better performance.
OK, so let’s analyze this one, I mean, less unsprung weight is good, no?
The weight difference between oxygen and nitrogen is less than 3%, but let’s take the full 3%.
One 255/40/17 summer tire holds approximately 13.88 liters (0.5 cu.ft.) of air at 2 bar (29.4 psi).
One liter of air is roughly equal to 1 gram so there are roughly 13.88 grams of air per tire, 55.52 grams in all 4 tires. Nitrogen is 3% lighter than oxygen, but there’s only 22% oxygen in air, so the difference in weight from all 4 tires is 0.3664 grams, that’s a whopping one third of a gram!
Here’s the math: 55.52 gr x 0.03 x 0.22 = 0.3664 gr
To put it in perspective, one official ping pong ball weighs 2.7 grams.
So, in essence, filling your tires with nitrogen won’t hurt anything and will provide some minimal benefits.
But, is it worth it?
Absolutely ... if you go to shops where it’s a free service with your new tires.
But paying an average of $10.00 per tire is absolutely not worth it.
Furthermore it may give you a false sense of security where you won’t regularly inspect your tires. Remember, even filled with pure nitrogen your tires will lose pressure over time.
Again, not true.
