Hutchy-SKO
please check out this picture of my coolant and tell me what you think https://drive.google.com/file/d/1s8j3Hz0mdTWOqjTexD64A3lahlw2rs0l/view
I will look into it I am low on tranny fluid so I was thinking it might be that? the oil is still full after driving 620 miles home 2 weeks ago. I will call around this week I want to get the oil analyzed too.looks like oil but you need to have your coolant analyzed to find out for sure because if it is you need to take immediate action to prevent major failure of the engine
what if it is engine oil, what is the solution in that case?If it is the tranny oil you can put a external cooler on the tyranny oil. clean the old cooler in the radiator and plug it off rather than replace the radiator
is it even safe to drive it 20 or so miles to a mechanic if I make sure all the fluids are topped off?I have same engine in mine. There's a few common causes on this engine. I would have a pro diagnose this if you don't want to just throw parts at it.. get the oil or coolant tested.
1. Head gasket is weak on the 24v. Seems to last about 150k-250k. Fix requires pulling the head, possibly having it machines, and replace every gasket on the top end. 8-16hours labor and $400 hard parts.
2. Air compressor leak. It uses oil and coolant and could have a bad seal. 4-8hrs
3. Oil cooler leak. Replace oil cooler. 4hours
A pro would probably be much faster, but those are my labor estimates knowing what I have to move to get at all these parts.
I think it's probably tranny fluid, the oil is still full and didn't lose a drop on a 620 mile drive home but the transmission is low on fluid. Also after that drive only a few drops of something was on the asphalt the next day. My plan is to change the oil, then fill the transmission and see how much was missing, drain and flush the radiator then refill and see how it acts. Does that sound ok?Oil in the water is a minor issue the real problem is when the water gets into the oil. When you shut it off the oil pressure drops to zero but the hot radiator still has pressure for hours and can force its way into the oil.
Oil in the water is a minor issue...
how do you get the fluids analyzed? I never heard of that until getting a buswatch for the antifreeze in both the engine and tranny oil when you change them but a oil analysis would catch that if it is getting contaminated. i would flush the radiator, drain a bit of oil from the oil pan (after it sat before starting as water will settle) then run it and see if it returns. if you have a water filter cut it open and do a good look inside it
