o1marc
Bluebird 1998 model with a build date of 6/18/1999.
What does the length code "length-3904" mean on the build sheet?
Also "W/S-STYLE = 4FF"?
If it's a 40'er, the length would be 39'4", FF probably designates Flat Front.
which would be better, 8.3 with md3060 and CAPS or 8.3l mechanical with mt643?
can the MT643 be swapped to md3060 with a stand alone controller?
you can swap in a MD3060 but you'll need a wiring harness, TCM, do some custom throttle work.. some 3000s had extra mounts that were required that werent required by the 643. .. the electronic shifter will be required.. unless you know your stuff. then go get a bus that already has a 3060
I don't necessarily know the MD3060 but fab'n mounts would be no problem.
There is non running buses outta Fl for under a grand that should have everything for the trans swap. My concern is they are saf t liners and the bus is a bluebird. Of course I could just put the mechanical set up in the non running Thomas.
Dang at at decisions....![]()
