In that case, Grats on the bus Smitty.
Have you tried the Milk Crate and prybar method of floor removal? You have to get it started, but once that is done, you sit on the crate and push the prybar. If you have to, use the crate as a fulcrum for the bar, then sit on the bar to lift the flooring. Or get yourself a log end to put under the prybar and then just stand on the high end.
