elkoskoolie
I have yet to do this; however, I read on busnut.com that one bus owner uses a second jack on the lug wrench handle to break the nuts loose. Safer than jumping on a breaker bar I guess. Thought I'd pass it along.
mightybus said:What is the best way to go about this? How tight should I torque the lug nuts? 22.5's. How can I break the bead on non split rims. Thanks. What is a good price to pay for a new tire? Thanks.
elkoskoolie said:Ingersall tight is NOT correct. This can stretch your studs. I'm not an expert, and can only repeat what I've read. Seems between 450 and 500 ft. lbs. is correct for bus lug nuts. I can't imagine that it's different for skoolies.
the_experience03 said:elkoskoolie said:Ingersall tight is NOT correct. This can stretch your studs. I'm not an expert, and can only repeat what I've read. Seems between 450 and 500 ft. lbs. is correct for bus lug nuts. I can't imagine that it's different for skoolies.
Ever met that 80 year old engine builder that has a torque wrench built into his forearm? Same idea.![]()
Elliot Naess said:![]()
, and it looked easy!
paul iossi said:you probably won't feel much either way, and both are messy to clean up![]()
