Seems like a good day for an update. Been a wild few days, weeks or months, something like that. Today marks my original "get it done by" goal. Looks like I'll be cutting things closer than I was hoping. Here's whats happened since my last update.
First off I got absolutely sick of finishing all my wood in my bus, it was way too claustrophobic. So I got me one of these nifty 10x20 carport tents from costco.
Much much better, finishing bed frame wood.
Got me a nice foldup table with some hideous graffiti on it for $10, featured in the back.
Took an 9 hour detour home through the olympic penninsula to pick up this beautiful piece of alder
Cut some holes in it for sink and stove
Dryfit
Traded a 11 day work week for 2x 3 day weekends, during the first 3 day weekend I made a couch and a cabinett to go above it.
Progress pix
Here we have one of my pull outs for the couch. Neighbors were not pleased about me welding and grinding to 3 in the morning.
Couch is assembled (mostly)
Pull out demonstration, I have 4 of these for full on customization. Is it a couch? a Bed? an L section couch? a C section couch? yes, yes it is. At 90" (or was it 92"?) this bed is almost 20" longer than my bed...But that's how it goes I guess.
Not comfy at all without wood panels..But I was incredibly relieved at this point to not have to haul this couch in and out of the bus anymore for awhile..Well I had to take it out again for the paint shop..
A pretty terrible picture of my couch shelf/cabinet, but the only progress pic I bothered to take..Next day I take this crap to the paintshop and begin my 11 day work week.
Some wood paneling for my bed frame/guitar storage box
Here we have my setup for my countertop. 4 layers of tung oil for color spaced 24 hours apart. Enter into my 2nd 3 day weekend. I wanted to try out an epoxy finish, on this but from what I heard epoxy is a delicate beast so I need to follow instructions to a T. One of which is to maintain a temperature between 70-80 degrees Fahrenheit. I hung up 3 heat lamps to a temperature controller (inkbird, $30ish on amazon), I checked the hourly forecast for the coldest few hours on the night to check on it periodically. at 67 degrees I concluded that I needed more heatlamps before proceeding with epoxy setup.
The next day was warmer, I setup an additional 4 lamps and ended up not using the original 3 at all, but i kept them handy in case the temperature couldn't keep up with my target. I also have the counter leveled and resting on 1inch square tubing scrap to avoid pooling at the bottom.
I didn't expect epoxy to take up my entire weekend, but I had to check on the curing process every 20 minutes and pick out bugs with toothpicls and then apply gentle heat via heatgun to smooth out the cure. After 3 days of neurotic babysitting, I got 1 base layer, 2 flood layers, and 2 touch up layers, maintained between 75-78 degrees fahrenheit.
Looks great! (in pictures atleast)
A few quick notes about my experiences with epoxy. 1. Keep toothpicks around 2. Clean up epoxy icicles vigilantly before it cures to avoid a headache alter (I had to sand them down and refinish my bottom with spar varnish). 3. If you sand epoxy, it will turn foggy, you'll need to throw another coat of epoxy on or throw on a topcoat of something to fill in the tiny cavities and return the shine (I used spar varnish). Overall I wouldn't recommend sanding epoxy unless it looks really bad. That said, I sanded down my sides to 320 and put two layers of spar varnish on the sides.
Dry fitting my dickinson P12000 propane furnace
I made some boxes to go in my closet to protect my propane and pex plumbing.
I had one of my old employees come over and help me sand at a generously low hourly rate. This coming week I have 30 more hours of sanding labor coming in from some great co-workers.
Picked up my couch and a new chest freezer, dry fit the new sink, thought it would be a good time for a photo.
Some of my couch utility being demonstrated. Also I started running some wires about.
Hairy foot for reference
Staining/Finishing more wood
