Hey there Skoolie folk!
I recently starting embarking on the journey of converting a school bus too!
It's a white 2015 gmc Savana bus which was used for people in wheelchairs.
This is my first official question! and first post on a forum ever for that matter. =)
So I've taken out all the benches as well and the wheelchair lift. I've stripped the floor right down to the metal.
Its a 2015, so the rust wasn't too bad. But we're in Quebec so there is some rust (lol) and some calcium looking spots, and definitely a lot of little holes (including a few because of rust).
I think I know what to do about all that. (Rust converter, rust-oleum protective enamel oil based paint, and silicon for the holes)
But my question pertains to the rest of the floor surface, which is the vast majority of the bus, which has this layer of thick brown grease on it. The grease definitely seems purposely put on by the manufacturer.
(I will attach pictures, and there's one where you see that this grease was applied with a paintbrush)
I managed to rub off a small area(see pic), with the help of an industrial degreaser (which didn't work very well actually), and a heck of a lot of elbow grease! lol ; and the metal underneath is perfectly rust free and looks very good.
Basically my question is whether this grease should be removed off the whole floor, in which case I would replace it with rust-oleum paint (and treat rust first where needed) or if this layer of grease will actually work as well as rust-oleum rust paint for protecting the floor from rust.
What do you guys think?
Any experience with this?
Does car manufacturer grease protect from rust? if so, as well as rust-oleum rust preventative paint?
I could take off this layer of grease, but it would be quite the job! (I am totally willing to do so mind you, if it would be better for the lifespan of our bus)
Also, I contacted the corroseal (rust converter product) company and the product adviser told me that this layer of grease was to protect the metal, but he didn't specify in which way. He didn't know the grease product and could not tell me if it would be better then rust-oleum to prevent rust or not.
Thanks so much everybody!
Santosh
p.s. I read the instructions of the rust-oleum paint and they say that all oil and grease etc needs to be removed before application....so I don't think the paint on top of the grease is a good option.
p.s.s If the consensus it to remove this layer of grease, which product works best? (because "Zep industrial purple degreaser" does not live up to my hopeful expectations) lol
Thanks!
Santosh
Thanks!
