So I switched out my headlights with a direct plug-n-play light and noticed my cruise control was spotty. Do you believe this could be fixed with the inline load resistor fix for the brake lights. You also have to keep the switch pulled to on or else they hyper flash.
If you only changed headlights, it is highly unlikely that a load resistor on the headlights will fix the problem. If you changed any of the brake lights for LEDs, then a load resistor might help. You would need to identify the cruise control's brake circuit and verify whether there are LEDs on that path. If so, it should help.
