wanderingturtl
Here are some things I've learned. What do y'all think? Did you find these things to be true? What else have you learned?
Lessons from Building a Bus
- Don’t expect to finish a build while you live in it. It’s not that easy to do.
- Finish all of a part before covering it up. You don’t want to go backwards to fix or finish it later.
- Inventory what you’ll need for a part of the build and order or procure parts ahead of time, before you plan to work on that part. If you don’t know what parts you’ll need to finish an area, get as far as you can and inventory what you need to proceed, and order or find the parts as soon as possible.
- Plan on everything taking longer and costing more than you expected.
- The bus walls are often not perpendicular to the floor. Do not plan on building next to vertical walls, unless you checked and your bus has vertical walls. They often lean inwards a little. The area of the floor at the bottom is not necessarily the same as the area 3’ or 6’ up.
- Build your framing and walls as square as possible. It’s a lot harder to build up to stuff that’s out of square; having square walls makes it easier.
- The plastic roof hatches will eventually leak or break. Be prepared for this, and don’t leave anything vulnerable to water damage under stock plastic roof hatches. The older the bus, the more true this is. Water can also run down the ceiling and drip somewhere else.
- Don’t expect to do everything yourself. Get help with sections that you aren’t good at, like plumbing or wiring.
