elliot_peas
Hey y'all! My bus is currently parked on a slope and I'd like to do some kinda ridiculous deck-block-jack-stand situation to get it level. Bus is 35ft long, and to get the back tire level with the front tire, it needs to be up about 2.5 ft. (Using supports of various appropriate heights under the frame, though).
This will be semi-permanent: I won't be driving the bus around, but it needs to be able to be relocated eventually.
A few years ago I used some 50ton bottle jacks from Harbor Freight and deck blocks and 4x4 posts to support and level an RV that was a little longer than my bus, but on less of a slope. I used six or eight "feet" made of a 4x4 stuck vertically into a concrete deck block.
I've attached a photo. Yes, it is as absurd as it looks. Let us all pause a minute to laugh.
Considerations: I don't want to jack this thing up and have it roll back on me. It is large and gravity is scary. There will be several other people involved in this project, so I at least won't be solo-ing it.
Y'all have any relevant examples of redneck engineering, techniques, supplies I should use? Are there super-heavy-duty RV jack stands that exist that would work?
I did check out other posts on the forum and I like the "dig a hole for the front tires" idea...
(Hey, update! My arm healed from that time I almost cut it off with an angle grinder while taking the bus ceiling out, and although I still haven't driven my bus yet, it did just complete it's third relocation after I spent two days working on the engine with a mechanic buddy, fixing a fuel leak and bleeding the lines & injectors, that was fun as heck. The bus has complete insulation, a floor and most of a new ceiling! Still enjoying myself even though it's an extremely slow process for me!)
