farok
- Joined
- Jan 10, 2019
- Posts
- 375
For those that have run a pair of Unistrut rails down the length of the bus, directly bolted to the roof, how did you level the two rails so that you can run a beam, solar panel, whatever across the two?
As it looks on my bus, the two rails will each need to be straightened about 5 degrees to get a level surface across the two.
So far the best bet I've found is pinion shims, aluminum shims that come in 2, 4, 6, and 8 degree variants. Not the cheapest option, but I'm hesitant to use composite construction shims up there where they'll be out in the weather.
Thoughts?
Chris
Thoughts?
Chris
