Ah, another opportunity for you to excel!
Does your AC blow?
That's the fan circuit board, that black wire bundle plugged into the connector on the board probably connects to a switch on the dash. Off, low medium, high, something like that.
A bus wiring diagram will tell you what should be connected-call the bus manufacturer or look them up on line. This is when you want to start learning about how your bus is wired up.
Someone has removed a bunch of wires from the relays. Those are the little black squares, the switches for the blower fan motor(s), and the heavy wires on the bottom go to the fan(s). Something doesn't look right though because each would have two heavy wires on the bottom. Like a wall switch, they need a wire in and a wire out on the bottom.
